Product BC Name: TNT SHM Order Function Line Items View
Use this user property to retrieve the business component instance in C++ code to evaluate search criteria and get the items while adding items to the function line items through the Search or Quick Add applet.
Property Description/Value
Value
Internal Product Popup
Parent Object Type
Internal Product Popup business component
Usage
Retrieves the business component instance in C++ code while adding items to the function line items through the Search Add applet. The second part of the user property name designates the view context. If the active view is the TNT SHM Order Function Line Items view, then the Internal Product Popup business component instance evaluates defined search criteria and gets the items.
