Product Search Fields
Use this user property to specify the Product fields in which a user can search using the Quick Add view.
Property | Description/Value |
Value |
Name, Product Type, TNT Display Name, TNT Unit of Measure, Part #, SHM Sub Category, Grouping Code, SHM Category, TNT Report Header, SHM Parent Category |
Parent Object Type |
TNT Attribute Search Applet applet |
Usage |
Specifies the Product fields on which a search can be done in the Quick Add view. |
