Querying for Related Function Spaces
You can run a query that displays not only the particular function space that meets your criteria but also any related function spaces. For example, consider a function space named Salon A, which includes Salon AB, Salon AC, and Salon ABC. If you run a query that returns Salon A, then you can choose to also show Salon AB, Salon AC, and Salon ABC.
To query for related function spaces
- Navigate to the Function Space Diary screen.
- In the Properties form, query for the property record.
- Click the appropriate view tab from one of the following: Sales/Execution, Revenue Management, Total Availability, or Compact Diary.
- From the selected view, enter the required start date, and then click Go. - Alternatively, you can specify the start date within the query assistant.
- On the view toolbar, click Query to display the query assistant.
- Enter your criteria in the Function Spaces section, and then click Go. - The function space most suitable for your requirements appears.
- On the view toolbar, click the menu button, and select Enable Query for Related Spaces. - The diary changes to display any function spaces that are related to the returned function space.
- To disable queries for related function spaces, from the diary view, click Menu, and choose Disable Query for Related Spaces. - If you have already run a query, then the diary changes to display only the original function space returned, hiding the related spaces from the view.
