Setting Up Report Headers for Non-Property-Specific Products
Administrators can associate any global report header with the products that are not assigned to any property.
To set up a report header for a non-property-specific product
  1. Navigate to the Administration - Product screen, then the Products view.
  2. In the Products list, query for and select the product to associate with a report header.
  3. In the Report Header field, click the select button, and select the report header.
    If more than one value is available, you can select multiple values. The value in the Property field for the product determines the values that you can select in the Report Header field.
