TNT Manual Allocation Field
Use this user property to set the allocation for the defined field in the case of a per person allocation.
Property Description/Value
Value
TNT Per Person Allocation
Parent Object Type
TNT SHM Quote Item, TNT SHM Invoice Order Item, TNT SHM Order Item business components
Usage
The value of this user property is a field, and the per person or system allocation value is set to this field. This user property is used in C++ code to set the appropriate allocation value for the child items of a package.
