TNT SHM Has Function Space Field
Use this user property to define whether or not the function space option is available for the function agenda.
| TNT SHM Has Function Space Field | Description |
Value |
N |
Parent Object Type |
TNT SHM Create Agenda Sub Function VBC business component |
Usage |
This user property is used in C++ code to manage function space functionality. By default, the value is N, indicating that function space is not available in the Opportunities screen, Function Agenda view. Modify the value to Y if function space is available for the function agenda. |
