TNT SHM Number of Nights Field
Use this user property to set the correct value of the Num Nights Duration field on a change of arrival date (that is, a change to the value of the Calculated Arrival Date field) or a change to the closed date (that is, a change to the value of the Hospitality Close Date field).
| Property | Description/Value |
Value |
Num Nights Duration |
Parent Object Type |
Opportunity Home Add Virtual business component |
Usage |
The value of this user property is a business component field. When the Calculated Arrival Date field or the Hospitality Close Date field is updated, a new value for the Num Nights Duration field is calculated and set by way of C++ code. |
