X-Axis Drill Down Enable
This user property is used to specify whether or not to set the field value of Drilldown Name.
| X-Axis Drill Down Enable | Description |
Value |
Y |
Parent Object Type |
TNT SHM Gantt AX Date Time Interval PopUp VBC business component |
Usage |
This user property specifies whether or not to set the field value of Drilldown Name. |
