Y-Axis Header Display Format
Use this user property to determine the format for the date to be displayed on the Y-Axis header in the Function Space Diary for some time scales.
Y-Axis Header Display Format Description
Value
MMMM YYYY
Parent Object Type
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary, and TNT SHM Function Space Diary Total Availability Applet applets
Usage
Specifies the Y-Axis header display format in the Function Space Diary, for example, August 2008. This user property is applicable only if month and year are displayed on the Y-Axis header.
