Y-Axis Width
This user property is used to specify the width of the Y-axis.
Value
Function Space Column Size
Parent Object Type
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary
Usage
This user property specifies the width of the Y-axis. The value of this user property is a column name in the User Preferences business component. This allows users to set their preferences for Y-axis width in the User Preferences screen.
