DB2 Authorizations Required
The following table lists the authorizations that are necessary to implement Siebel CRM on DB2 for z/OS.
| Task | Authorization Required | Task Command Example |
Alter a buffer pool. |
SYSADM, SYSCTRL, SYSOPR |
Grant use of a buffer pool. |
SYSADM, SYSCTRL |
Grant CREATEIN for triggers. |
SYSADM, SYSCTRL |
Create a storage group. |
SYSADM, SYSCTRL, CREATESG |
Grant use of a storage group. |
SYSADM, SYSCTRL |
Grant CREATEDBA and DBADM authority. |
SYSADM, SYSCTRL |
Create a database. |
SYSADM, SYSCTRL, CREATEDBA, CREATEDBC |
Alter a table space. |
DBADM, SYSADM, SYSCTRL |
Create a table space. |
SYSADM, SYSCTRL, DBADM, DBCTRL, DBMAINT, CREATETS |
Modify DB2 Connect package (if package already exists). |
DBADM, SYSADM, BIND privilege on the package, ALTERIN privilege on the schema |
Add DB2 Connect package (if a package does not already exist). |
DBADM, SYSADM, BINDADD privilege, and IMPLICIT_SCHEMA authority on the database if the schema name does not exist CREATIN privilege on the schema if the schema name of the package exists |
Alter a table. |
Create a table. |
SYSADM, SYSCTRL, DBADM, DBCTRL, DBMAINT, CREATETAB |
Alter an index. |
Create an index. |
SYSADM, SYSCTRL, DBADM, DBCTRL |
Grant CREATE or PACKADM for stored procedures. |
SYSADM, SYSCTRL |
Grant BINDADD. |
SYSADM, SYSCTRL |
Grant SELECT on catalog tables. |
SYSADM, SYSCTRL |
Create User-Defined Functions |
SYSADM, DBADM |
