MS_IDENT Column for DB2 for z/OS
The MS_IDENT column exists in every EIM table and is specific to DB2 for z/OS. It allows DB2 for z/OS to automatically generate unique and sequential values for each row in a table. This column is the unique identity column created using the Generated Always with Identity option.
Caution:
If you load data into this column using load utilities, your import might fail. Such a failure can occur particularly when migrating data from a Siebel application on DB2 for UNIX or Windows to a Siebel application on DB2 for z/OS.
