Example of Custom Method for Custom Attributes
To create a custom attribute, you must create a custom method that the attribute calls. Here is an example of how you could use eScript to write a custom method named GetValuesCustomAttribute to be used by a custom attribute.
function GetValuesCustomAttribute(inputs, outputs)
   try{
   // All the field values would be in the format Object.Field.Field Name. All the
   // values would be passed to custom attributes.
   // Avoid Using transaction Id and querying transaction BC, as in simulation
   // mode the attributes passed in transaction are passed to simulation. Always use
   // the values from the Transaction.Field.Field Name.
   var strOrgAirPort   =  inputs.GetProperty ("Transaction.Field.Origination Airport");
   var strDestAirPort  =  inputs.GetProperty ("Transaction.Field.Destination Airport");
   var customCoeff    =  inputs.GetProperty ("Transaction.Field.Custom Coeff Factor");
   var points = 0;
   if(strOrgAirPort == "SFO" &&strDestAirPort ="BOS")
   points = 200 * customCoeff;
   outputs.SetProperty("Field Value",points);
   catch(e)
   TheApplication().RaiseErrorText(e.toString());
   finally
