Setting Parameters for the Siebel Loyalty Engine
You can customize the following Siebel Loyalty Engine parameters:
  • LOYEngineNumberOfRuns
  • LOYEngineQueueObjects
  • LOYEngineSleepTime
All these parameters apply to the eLoyalty Processing Engine – Batch component. They affect batch processing, not real-time processing. For a description of these parameters, see Configuring Parameters of the Batch Server Component.
Parameters are commonly used in the following ways:
You can also set parameters to determine how often statements are produced for each tier of a program by using the Statement Frequency and Only If Activity fields of the Program screen, Tier Class, Tiers view. For more information, see Defining Tier Classes and Tiers.
