ActivateMultipleFields Method for a Business Component
The ActivateMultipleFields method activates multiple fields. This method returns one of the following values:
  • TRUE if the activation is successful
  • FALSE if the activation is not successful
Format
BusComp.ActivateMultipleFields(SiebelPropertySet)
The following table describes the arguments for the ActivateMultipleFields method.
Argument Description
SiebelPropertySet
Property set that identifies a collection of properties. These properties identify the fields that Siebel CRM must activate.
Used With
COM Data Control, COM Data Server, Siebel Java Data Bean, Mobile Web Client Automation Server, Server Script
Examples
The following example is for Siebel Java Data Bean:
import com.siebel.data.*;
//Create Siebel Java Data Bean.
//log in to Siebel Java Data Bean
//Create Siebel Bus Object.
//Get the Bus Object from SiebelDataBean
//Create Siebel Bus Comp siebBusComp
//Get the business component using SiebelBusObject
SiebelPropertySet ps = new mdata_bean.NewPropertySet();
ps.setProperty("Account Products","");
ps.setProperty("Agreement Name","");
ps.setProperty("Project Name","");
ps.setProperty("Description","");
ps.setProperty("Name","");
siebBusComp.ActivateMultipleFields(ps);
The following Siebel eScript example queries the Contact business component and returns the First Name and Last Name of the first contact that it finds:
var ContactBO = TheApplication().GetBusObject("Contact");
var ContactBC = ContactBO.GetBusComp("Contact");
with (ContactBC)
   SetViewMode(AllView);
   var fieldsPS = TheApplication().NewPropertySet();
   var valuesPS = TheApplication().NewPropertySet();
   fieldsPS. SetProperty("Last Name", "");
   fieldsPS.SetProperty("First Name", "");
   ActivateMultipleFields(fieldsPS);
   ClearToQuery();
   ExecuteQuery(ForwardBackward);
   if (FirstRecord())
      GetMultipleFieldValues(fieldsPS, valuesPS);
      var slName = valuesPS.GetProperty("Last Name");
      var sfName = valuesPS.GetProperty("First Name");
Related Topics
For more information, see the following topics:
