FirstSelected Method for a Business Component
The FirstSelected method makes the first record of the multiple selection in a business component active. It also calls any associated events. It returns the same information as the FirstRecord method. For more information, see FirstRecord Method for a Business Component.
Format
BusComp.FirstSelected
No arguments are available.
Used With
COM Data Server, Server Script
Examples
The following examples use the FirstSelected method and the NextSelected method to allow you to customize multirecord deletion. If the user clicks a custom button in an applet, then Siebel CRM can call this code and it can call the Delete Selected custom method.
The following example is in Siebel eScript:
function BusComp_PreInvokeMethod (MethodName)
   if (MethodName == "Delete Selected")
      with (this)
         var iRecord = FirstSelected();
         while (iRecord)
            DeleteRecord();
            iRecord = NextSelected();
      return (CancelOperation);
   return (ContinueOperation);
The following example is in Siebel VB:
Function BusComp_PreInvokeMethod (MethodName As String) As Integer
   Dim iRtn As Integer
   iRtn = ContinueOperation
   If MethodName = "Delete Selected" Then
      With me
         Dim iRecord As Integer
         iRecord = .FirstSelected
         While iRecord
            .DeleteRecord
            iRecord = .NextSelected
         Wend
      End With
      iRtn = CancelOperation
   End If
   BusComp_PreInvokeMethod = iRtn
End Function
