NextRecord Method for a Business Component
The NextRecord method moves the record pointer to the next record in a business component, making that record the current record. This method returns the following information:
  • In Siebel VB, an integer that includes one of the following values:
    • 1. Indicates the method successfully moved the record pointer to the next record.
    • 0 (zero). Indicates the method did not move the record pointer because it points to the last record.
  • In Siebel eScript and COM, a Boolean value.
Format
BusComp.NextRecord
No arguments are available.
Used With
COM Data Control, COM Data Server, Siebel Java Data Bean, Mobile Web Client Automation Server, Server Script, Browser Script
Examples
The following example is in Siebel eScript:
var isRecord;
with (this)
  ClearToQuery();
  SetSearchSpec("Name", "A*");
  ExecuteQuery(ForwardBackward);
  isRecord = FirstRecord();
  while (isRecord)
    // do some record manipulation
    isRecord = NextRecord();
For a similar Siebel VB example, see FirstRecord Method for a Business Component.
