PreviousRecord Method for a Business Component
The PreviousRecord method moves the record pointer to the previous record in a business component, making that record the current record. This method returns one of the following values:
  • An integer in Siebel VB that includes one of the following values:
    • 1. Indicates the method successfully moved the record pointer to the next record.
    • 0 (zero). Indicates the method did not move the record pointer because it points to the last record.
  • A Boolean value in Siebel eScript and COM.
Format
BusComp.PreviousRecord
No arguments are available.
Usage
You can use the PreviousRecord method only on a business component that Siebel CRM has queried with the CursorMode mode argument set to ForwardBackward. For more information, see ExecuteQuery Method for a Business Component.
Used With
COM Data Control, COM Data Server, Siebel Java Data Bean, Mobile Web Client Automation Server, Server Script
Examples
The following Siebel eScript example locates the next-to-last record in a query and then manipulates it:
with (this)
  ActivateField("Name")
  ClearToQuery();
  SetSearchSpec("Name", "A*");
  ExecuteQuery(ForwardBackward);
  isRecord = FirstRecord();
  while (isRecord)
    // do some record manipulation
    isRecord = NextRecord();
    } // end while loop
  nextToLastRecord = PreviousRecord();
  if (nextToLastRecord)    // verify that there is a penultimate record
  // do some more record manipulation that applies only to next-to-last record
  } // end if
} // end with
