| AddChild Method for a Property Set | Adds child property sets to a property set. | Dim oPropSet as SiebelPropertySet
 Dim iIndex as Integer
 iIndex
= oPropSet.AddChild(childObject as Property Set)
| Copy Method for a Property Set | Returns a copy of a property set. | Dim oPropSet1 as SiebelPropertySet
 Dim oPropSet2 as SiebelPropertySet
 oPropSet2 = oPropSet1.Copy()
| GetChild Method for a Property Set | Returns a child property set of a property
 oPropSet1 = oPropSet.GetChild(index as
Integer)
| GetChildCount Method for a Property Set | Returns the number of child property sets
that exist for a parent property set. | Dim oPropSet as SiebelPropertySet
 Dim iCount as Integer
 iCount
= oPropSet.GetChildCount()
| GetFirstProperty Method for a Property Set | Returns the name of the first property in
 Dim sPropName as String
 sPropName
= oPropSet.GetFirstProperty()
| GetNextProperty Method for a Property Set | Returns the name of the next property in
 sPropName
= oPropSet.GetNextProperty()
| GetProperty Method for a Property Set | Returns the value of a property. | Dim oPropSet as SiebelPropertySet
 Dim sPropVal as String
 sPropVal
= oPropSet.GetProperty(propName as String)
| GetPropertyCount Method for a Property Set | Returns the number of properties that exist
in the current level in the hierarchy.  | Dim oPropSet as SiebelPropertySet
 Dim count as Long
 count = oPropSet.GetPropertyCount
| GetType Method for a Property Set | Returns the value of the type attribute of
 Dim sTypeVal as String
 sTypeVal
= oPropSet.GetType()
| GetValue Method for a Property Set | Returns the value of the value attribute
of a property set. | Dim oPropSet as SiebelPropertySet
 Dim sValVal as String
 sValVal
= oPropSet.GetValue()
| InsertChildAt Method for a Property Set | Inserts a child property set in a parent
property set at a specific location. | Dim oPropSet as SiebelPropertySet
 oPropSet.InsertChildAt(childObject as SiebelPropertySet,
index as Long)
| PropertyExists Method for a Property Set | Returns a Boolean value that indicates if
the property that the argument identifies exists. | Dim oPropSet as Property Set
 Dim propExists as Boolean
 propExists
= oPropSet.PropertyExists(propName as String)
| RemoveChild Method for a Property Set | Removes a child property set from a parent
 oPropSet.RemoveChild(index as Long)
| RemoveProperty Method for a Property Set | Removes a property from a property set. | Dim oPropSet as SiebelPropertySet
 oPropSet.RemoveProperty(propName as String)
| Reset Method for a Property Set | Removes every property and child property
set from a property set. | Dim oPropSet as SiebelPropertySetoPropSet.Reset()
| SetProperty Method for a Property Set | Sets a value in the property of a property
 oPropSet.SetProperty(propName as
String, propValue as String)
| SetType Method for a Property Set | Sets the value for the type attribute of
 oPropSet.SetType(value as String)
| SetValue Method for a Property Set | Sets the value for the value attribute of
 oPropSet.SetValue(value as String)
