ProductRecommendation
The following tables describe the signal action and list the parameter that you must modify to implement dynamic pricing for the ProductRecommendation signal.
| Definition | Service Type | Service Name | Mode | Instance Type |
Action |
Workflow |
Product Recommendation Driver Workflow |
Not applicable |
Line Item |
| Name | Value |
SubPSPPricingWFName |
Dynamic Pricing Procedure |
