Multiple Operands
You can add multiple operands to an exclude constraint by clicking the Compound Field button when you create the constraint.
For example, you could create the constraint:
Item A excludes Item B > 2, Item C < 5
This constraint means the following:
If Item A is present in the solution, Item B cannot be greater than 2
If item A is present in the solution, Item C cannot be less than 5
If Item B is greater than 2 in the solution, Item A cannot be present
If item C is less than 5 in the solution, Item A cannot be present
Using commas to separate expressions is the same as writing two constraints:
Item A excludes Item C < 5
If you want to write a constraint where you exclude the combination of two conditions you would do it as follows:
Item A excludes (Item B > 2 AND Item C < 5)
This constraint means that if Item A is present in the solution, the two conditions cannot be simultaneously true in the same solution. If Item A is present, the quantity of Item B can be greater than 2 as long as the quantity of Item C is not less than 5 and conversely.
