Operating System Environment Variables Used with Siebel Configurator
When you are setting up Siebel Product Configurator, it can be useful to set the operating system environment variables described in the following table.
| Variable Name | Description |
CFG_BROKER_FS |
Additional file system directory used by the Broker to support multiple file system locations. The value of this variable is appended to the list of possible locations. When remote Siebel Product Configurator is used, set this variable on both the operating system of the Application Object Manager and the operating system of the remote Siebel Product Configurator. It is used by the object broker and object administration. |
CFG_IGNORE_MISSING_ELEMENTS |
Flag to determine whether to ignore the overwritten attributes with the missing base definitions. The possible values are TRUE or FALSE. When remote Siebel Product Configurator is used, set this variable on the operating system of the remote Siebel Product Configurator. It is used by the factory. |
CFG_PASSWORD |
Login password used in remote service. When remote Siebel Product Configurator is used, set this variable on the operating system of the Application Object Manager. It is used by the remote proxy. |
CFG_USERNAME |
Login user name used in remote service. When remote Siebel Product Configurator is used, set this variable on the operating system of the Application Object Manager. It is used by the remote proxy. |
PRESERVE_ENGINE_AND_USER_PICKS |
Flag to determine whether the application preserves engine and user pick. The possible values are Y or N. When remote Siebel Product Configurator is used, set this variable on the operating system of the remote Siebel Product Configurator. It is used by the instance service. |
SIEBEL_ENFORCE_REQUIRED_ATTRIBUTES |
Flag to determine whether the application enforces the required attributes. The possible values are Y or N. When remote Siebel Product Configurator is used, set this variable on both the operating system of the Application Object Manager and the operating system of the remote Siebel Product Configurator. It is used by the engine and the user interface. |
SKIP_HIDDEN_AND_NOT_REQUIRED_ATTRIBUTES |
Flag to determine whether the application skips the attributes that are hidden and not required. The possible values are Y or N. When remote Siebel Product Configurator is used, set this variable on the operating system of the remote Siebel Product Configurator. It is used by the instance service and session. |
SEBL_CFG_SEARCH_LIMIT |
The number that determines the search limit. Used to limit the counter for the number of failed searches. Set on all application servers. By setting a very high number, you tell the engine not to exit the solve operation. In some cases, if the engine cannot find a solution after a reasonable number of iterations, it displays an error message, but if this variable has a high value, it keeps trying, which can slow the response time to unacceptable levels. When remote Siebel Product Configurator is used, set this variable on the operating system of the remote Siebel Product Configurator. |
VOD_PROFILER_ON |
Flag to determine whether to collect the statistical data on instrumented functions. The possible values are TRUE or FALSE. When remote Siebel Product Configurator is used, set this variable on both the operating system of the Application Object Manager and the operating system of the remote Siebel Product Configurator. |
