Set Procedural Conditional Variable Template
The Set Procedural Conditional Variable template has the form:
[Item or condition] sets Procedural condition variable value to true
This template defines a variable on the product instance. This variable's name is the rule name, and its value is evaluated after each user click. The variable can be retrieved from the Siebel Product Configurator service using a script and can be used to control the application behavior dynamically.
