Setting the Server Parameter to Enable Pre-Pick Compatibility on the Siebel Developer Web Client
Use the following procedure to set the server parameter to enable pre-pick compatibility on the Siebel Developer Web Client.
To enable pre-pick compatibility
Use any text editor to open the .cfg file of the Siebel Developer Web Client.
If the InfraObjMgr section already exists, add the following line to that section:
PrePickCompatibilityEnabled = TRUEIf the InfraObjMgr section does not already exist, add both the section header and the line to the .cfg file, as follows:
[InfraObjMgr]PrePickCompatibilityEnabled = TRUE
