Mobile Products That Siebel CRM Supports
The following table describes mobile products that Siebel CRM supports.
Product Group Supported Application Reference
Siebel Remote
Siebel Remote supports almost all Siebel CRM applications.
You can use the following reference sources:
  • Siebel Remote and Replication Manager Administration Guide (this guide)
  • Siebel Installation Guide
Siebel Mobile Applications
Siebel Mobile connected applications
Siebel Mobile disconnected applications
  • Siebel Mobile Guide: Connected
  • Siebel Mobile Guide: Disconnected
