Using the Move Siebel Remote Client Parameter
If the remote client is currently registered on a Siebel Server that is not the current server, and if you set the Move Siebel Remote Client parameter to TRUE, then the following occurs:
The Database Extract server component sets the Siebel Server name of the remote client to the local Siebel Server.
The following server components on the old server stop servicing this remote client in the next iteration:
Transaction Router
Transaction Merger
Database Extract
You can also use the Move Siebel Remote Client parameter to move a regional node in the same way you that you use this parameter to move a remote client.
The default value is FALSE.
If you attempt to extract a remote client that Siebel Remote already extracted for a different server, then the Database Extract server component returns an error.
