Changing Siebel Administrator Account Password
Before you run the Database Configuration Wizard to configure the Siebel database on the RDBMS, you must create a Siebel administrator account, either manually (on IBM DB2) or using the grantusr.sql script. The default user ID for the Siebel administrator account is SADMIN (case-sensitive). You must also create a password for the account. The password you assign to the Siebel administrator account cannot be the same as the user name of the account. The password for the Siebel administration account must not exceed 18 characters - for more information, see Characters Supported in Siebel Passwords.
Note: It is strongly recommended not to change the name of the Siebel
administrator account, SADMIN. This account must be created so that you can log in to
Siebel applications as Siebel administrator. For more information about setting up the
Siebel administrator account (SADMIN) for initial use, see Siebel Installation Guide.
