Mapping Language Code of Siebel CRM to Oracle Real-Time Scheduler
This integration uses the SBL_ORS_LanguageCodeMapping DVM to map the Siebel's Language Code to Oracle Real-Time Scheduler's Language Code. This mapping is being used to support Multilingual deployment in Siebel CRM and Oracle Real-Time Scheduler.
Requirements for Mapping a Language Code
If you use the SBL_ORS_LanguageCodeMapping DVM, then you must make sure your mapping meets the following requirements:
  • The Language Code defined at Siebel CRM should be mapped to corresponding Language Code at Oracle Real-Time Scheduler.
Examples of Mapping a Language Code
Siebel Column ORS Column
ENU
ENG
ESN
ESA
