About Setting Up Siebel Territory Management
This chapter describes administration tasks that are specific to Siebel Territory Management. Use this chapter in combination with Siebel Applications Administration Guide and Siebel Security Guide.
Siebel Applications Administration Guide and Siebel Security Guide cover the setup tasks that are common to all Siebel Business applications, such as using license keys, defining employees, and defining your company’s structure. Siebel Applications Administration Guide also provides the information that you need to perform data administration and document administration tasks.
This guide assumes that you have already installed or completed the upgrade of your Siebel Business application. If you have not, go to the Siebel Bookshelf, and click the links to the guides that are relevant to your company’s implementation.
Note: The Siebel Bookshelf is available on Oracle Technology Network (http://www.oracle.com/technetwork/indexes/documentation/index.html) and Oracle Software Delivery Cloud. It might also be installed locally on your intranet or on a network location.
Siebel Installation Guide describes how to create the Siebel Administrator account used to perform the tasks described in this guide.
