Running Territory Alignments
When you run an alignment, a job is submitted to the Workflow Process Manager. The workflow creates assignment rules and submits a batch job to Assignment Manager. When the Assignment Manager job has finished, the results are presented in the Results view of the Siebel Territory Management screen.
No changes are made to the current assignments of accounts, contacts, or assets in the database—these changes do not occur until the alignment becomes active.
Note: While an alignment is being run, no other alignment in the same hierarchy
can be run at the same time.
