Setting up Assignment Manager’s Load Splitter for Siebel Territory Management
Siebel Assignment Manager is used to run territory alignments, and you must set up the load splitter that distributes the load of records for processing in Assignment Manager. For more information, see Siebel Assignment Manager Administration Guide.
This task is a step in Process of Setting Up Siebel Territory Management.
To set up load splitter
  1. Navigate to the Assignment Administration screen, Load Splitter Configuration view.
  2. Create a new record in the Load Splitter Configuration applet and complete the necessary fields, described in the following table.
    Field Comments
    Name
    Enter your machine’s name.
    Threshold
    Enter 10,000
    Minimum Batch Size
    Enter 5,000
  3. Scroll down and create a new record in the Server Configuration Applet. Complete the necessary fields, described in the following table.
    Field Comments
    Priority
    Enter 1
    Server Name
    Enter the name of your server.
    Number of Tasks
    Enter 10
  4. Write down the Configuration ID for the current record in Load Splitter Configuration applet.
  5. Set system preferences:
    1. Navigate to the Administration - Application screen, System Preferences view.
    2. Query for RunAlignmentLoadBalancerConfig and ActivationLoadBalancerConfig.
    3. If you cannot find these properties, create them.
    4. Set the values of these properties to the Configuration ID you copied in Step 4.
  6. Synchronize the server:
    1. Navigate to the Administration - Server Configuration screen, Enterprises, and then Synchronize view.
    2. Click the Synchronize button.
    3. Wait until the task is finished.
