Aborting a Running Migration Plan
This procedure describes how to stop a running migration plan. This is useful if, for example, you selected the wrong source integration branch when executing the migration plan. When you stop a running migration plan, the following happens:
All resource tasks within the migration plan will also end.
The status on any currently running resources changes to Stopped and the migration plan's status changes to Stopped, and this information is moved to the History screen. For more information, see Viewing Migration History.
The resource that is running in the Source or Target environment will continue to run until it completes – there is no way to stop this nor to rollback the resource (that is currently running or already completed).
To abort a running migration plan
In the Siebel Migration Application, click Execution in the navigation menu in the side panel to go to the Execution screen.
Identify and select a migration plan (for example, Data Export) with a status of Running that you want to stop.
Click Stop in the Action field.
Click OK when prompted with the following (or similar) message:
Are you sure you want to stop the execution? -
When the stop operation completes, click OK when prompted with the following (or similar) message:
The execution for the Migration Plan '<Name_of_Plan> - YYYY-MM-DD Hr:Min:Sec' was successfully stopped.In the Execution screen, note that the '<Name_of_Plan>' migration plan will stop running and the Run (or play) icon in the Action field will be enabled for the record so that you can execute the plan again.
Click History in the navigation menu in the side panel to go to the History screen.
Notice that the '<Name_of_Plan>' migration plan that you stopped in step 3 has a status of Stopped. For more information, see Viewing Migration History.
(Optional) To re-execute the migration plan that you stopped in step 3, return to the Execution screen, select the migration plan, and then click Run in the Action field.
