Obtaining Required IBM Utilities
Verify that the following IBM utilities are available for your upgrade to the current release of Siebel CRM:
DSNTEP2. The upgrade uses DSNTEP2 to execute SQL.
Prepare and bind DSNTEP2 by following the procedures in your IBM installation documentation. If you made local modifications, you might have to prepare and bind a separate version. Also, if you are using a separate version of DSNTEP2, you have to change the SIEBSQL* members to reflect the new plan and program names.
DFSORT. The utility DFSORT is used to manipulate data for data migration during upgrade.
LOAD. The IBM DB2 Load utility is used to load data during data migration.
REBUILD INDEX. The IBM DB2 REBUILD INDEX utility (DSNUTILB) is used to build indexes after they are created using
DEFER YES.IEBCOPY. The utility IEBCOPY is used to create members in installation data sets. Sequential data sets contains control information used by IEBCOPY.
IEBGENER. The utility IEBGENER is used to copy sequential data sets.
DSNTIAUL. The upgrade uses DSNTIAUL to unload Siebel application data.
Compile, link-edit, and bind DSNTIAUL by following the procedures in your IBM DB2 installation documentation.
For information on these IBM utilities, see your IBM documentation.
