Restarting the Siebel Upgrade Wizard After Pauses
Use this procedure to restart the Upgrade Wizard after it has paused to allow you to apply files generated on the midtier to the z/OS host.
To restart the Upgrade Wizard
Navigate to the
DBSRVR_ROOT\DB2390\dboutput\upgradedirectory (Windows) or the$DBSRVR_ROOT/DB2390/dboutput/upgradedirectory (UNIX).Do the following:
Windows: Double-click on the
upg_restart.batfile.UNIX: Run
upg_restart.ksh.
