Supported Upgrade Paths for Siebel CRM
The repository for the current release of Siebel CRM is SIA. Two types of optional repositories are offered while running Siebel CRM installer:
Master Repository. This is required for the following situations:
You are upgrading from a pre-Siebel CRM 17.0 release.
You are creating a new Siebel CRM database instance.
Ancestor Repositories. These are required if you are upgrading from a pre-Siebel CRM 17.0 release.
Review the information in the following table to determine if you need either of these repositories, and to ensure that they are available. If these repository options were not selected during installation, re-run the installer and add as needed. For more information, see Siebel Installation Guide for the operating system you are using.
Current Version |
Upgrade Version |
Upgrade Approach |
Upgrade Tasks |
Siebel CRM version 7.5.3 through version 7.7.2 (SEA or SIA repository) |
Siebel CRM 22.7 Update |
The upgrade approach is:
Perform the following two-step repository upgrade:
For more information, see Performing the Siebel Incremental Repository Merge. |
The current Siebel CRM version is one of the following:
Perform the following upgrade tasks:
The New Customer Repository, generated through a three-way repository merge, contains all of the update content from Siebel CRM 22.7 Update. For more information about repository merge, see Performing the Siebel Repository Merge. |
Siebel CRM version 17.0 or later |
Not applicable. |
Neither an Incremental Repository Merge nor a Database Upgrade is required for Siebel CRM 17.0 or later (including 18.x, 19.x, 20.x, and 22.x). For more information on installing monthly updates, see the roadmap for installing Siebel CRM 22.x Update for an existing installation of Siebel CRM 17.x or later in Siebel Installation Guide for the operating system you are using. |
