Error Code and Error Text for Siebel VB Errors
The following table lists the run-time errors that Siebel VB returns. The On Error statement can handle these errors. The Err function can query the error code and the Error function can query the error text. For more information, see the following topics:
| Error Code | Error Text |
5 |
Illegal function call |
6 |
Overflow |
7 |
Out of memory |
9 |
Subscript out of range |
10 |
Duplicate definition |
11 |
Division by zero |
13 |
Type Mismatch |
14 |
Out of string space |
19 |
No Resume |
20 |
Resume without error |
28 |
Out of stack space |
35 |
Sub or Function not defined |
48 |
Error in loading DLL |
52 |
Bad file name or number |
53 |
File not found |
54 |
Bad file mode |
55 |
File already open |
58 |
File already exists |
61 |
Disk full |
62 |
Input past end of file |
63 |
Bad record number |
64 |
Bad file name |
68 |
Device unavailable |
70 |
Permission denied |
71 |
Disk not ready |
74 |
Can't rename with different drive |
75 |
Path/File access error |
76 |
Path not found |
91 |
Object variable set to Nothing |
93 |
Invalid pattern |
94 |
Illegal use of NULL |
102 |
Command failed |
429 |
Object creation failed |
438 |
No such property or method |
439 |
Argument type mismatch |
440 |
Object error |
901 |
Input buffer is larger than 64K |
902 |
Operating system error |
903 |
External procedure not found |
904 |
Global variable type mismatch |
905 |
User-defined type mismatch |
906 |
External procedure interface mismatch |
907 |
Pushbutton required |
908 |
Module has no MAIN |
910 |
Dialog box not declared |
