File Input and Output Quick Reference
The following table lists methods that you can use to manipulate data in a file.
Statement Purpose Reference
Eof
Determines if the end of an open file has been reached.
End of File Method
Get
Reads the content of a file, and then places this content in a variable.
Force Explicit Declaration Statement
Input
Returns a string of characters from a file.
Get Characters From File Method
Input filenumber, variable
Reads data from a file, and then saves this data to different variables.
Parse File Contents Method
Line Input
Reads a line from a sequential file, and then saves it in a string variable.
Get Line From File Method
Loc
Returns the current offset of a file.
Get File Offset Method
Print
Prints data to a file or to the screen.
Print Data to File Method
Put
Writes a variable to a file.
Write Variable to File Method
Seek filenumber
Returns the current position for a file.
Get File Position Method
Seek filenumber, position
Sets the position of the next read or write operation in an open file.
Set File Position Method
Spc
Prints a number of spaces.
Print Spaces Method
Tab
Sets the current print position.
Set Print Position Method
Width
Sets the output line width for an open file.
Set File Width Method
Write
Writes data to a sequential file.
Write Data to File Method
