Get a String of Spaces Method
The Get a String of Spaces method returns a string of spaces.
Format
Space[$](number)
For information about the dollar sign, see Usage of the Dollar Sign.
The following table describes the arguments that you can use with this method.
| Argument | Description |
number |
A numeric expression that specifies the number of spaces to return. This number can be any numeric data type, but this method rounds the number to an integer. This number must reside in the range of 0 through 32,767. |
Example
For an example, see Get Octal Method.
