How Declaring a Variable Affects Variable Scope
The following table describes how you declare a variable affects variable scope.
Scope | Where the Variable Is Declared |
Local |
Declared in a subroutine or function. Only the subroutine or function that declares the variable can access this local variable. |
Module |
Declared in the general declarations section. Any subroutine, function, or event that is attached to the object in the script window that displays this variable can access this modular variable. |
Global |
Declared in one of the following items:
You can write code that accesses a global variable throughout the Siebel application. For more information, see Siebel Technical Note #217 on My Oracle Support. |
