ODBC Close Connection Method
The ODBC Close Connection method is a Siebel VB method that disconnects from an ODBC data source connection that the ODBC Open method established. It returns a variant that includes one of the following values:
  • 0. Successful disconnect.
  • -1. Connection is not valid.
If you call the ODBC Close Connection method with an argument that is not valid, then it replies with the undocumented return code of -2 (negative two), which indicates a data source connection that is not valid. The following items are examples of arguments that are not valid:
  • An SQLClose(0) argument
  • A variable argument that does not contain an initial value
Format
SQLClose(connection)
The following table describes the arguments that you can use with this method.
Argument Description
connection
A named argument that the ODBC Open method returns. It must be a long integer. For information about named arguments, see Comments and Call Subroutine Method.
Example
The following example opens the data source named SblTest, gets the names in the ODBC data sources, and then closes the connection:
Sub Button_Click
'   Declarations
   Dim outputStr As String
   Dim connection As Long
   Dim prompt As Integer
   Dim datasources(1 To 50) As Variant
   Dim retcode As Variant
   prompt = 5
'   Open the data source "SblTest"
   connection = SQLOpen("DSN = SblTest", outputStr, prompt: = 4)
   action1 = 1 ' Get the names of the ODBC data sources
   retcode = SQLGetSchema(connection: = connection,action: _
   = 1,qualifier: = qualifier, ref: = datasources())
'   Close the data source connection
   retcode = SQLClose(connection)
End Sub
