Right-Justify String Method
The Right-Justify String method right-justifies one string in another string. It does not return a value. It justifies a string in the following ways:
Value in the string argument is longer than string-expression. It replaces the leftmost characters of the string with spaces.
Value in the string argument is shorter than string-expression. It copies only the leftmost characters of string-expression.
You cannot use it to assign variables of different custom types.
Format
Rset string = string-expression
The following table describes the arguments that you can use with this method.
Argument | Description |
string |
The string that receives the right-aligned characters. |
string-expression |
The string that this method puts into the string that the string argument contains. |
Example
The following example right-justifies an amount that the user enters in a field that is 15 characters long. It then pads the extra spaces with asterisks (*) and adds a dollar sign ($) and decimal places, if necessary:
Sub Button_Click
Dim amount as String * 15
Dim x as Integer
Dim msgtext as String
Dim replacement as String
Dim position as Integer
replacement = "*"
amount = 234.56
position = InStr(amount,".")
If position = 0 then
amount = Rtrim(amount) & ".00"
End If
Rset amount = "$" & Rtrim(amount)
length = 15-Len(Ltrim(amount))
For x = 1 to length
Mid(amount,x) = replacement
Next x
End Sub
