Using a Label to Handle Custom Errors
The following image includes an example that uses a label to handle a custom error.
Example That Handles Custom Errors With a Label. This image is described in surrounding text.
Explanation of Callouts
The example that uses a label to handle a custom error includes the following items:
  1. Place the code that handles the error immediately before the line of code that could cause an error.
  2. Use a labeled section of code to handle the custom error.
