Associating Parts with Supplier Warranty Policies
This topic describes how to associate parts with a supplier warranty policy.
To associate parts with a supplier warranty policy
Navigate to the Supplier Warranty Policies screen, then the Supplier Warranty Policies view.
Drill down on the supplier warranty policy with which you want to associate parts.
In the Line Items section, click New.
Enter the part name, or click the single select button in the Part Name field to select from the Pick Product dialog box.
Define the line item by entering data in the line item fields. The following table describes some fields.
Field Description Operation Code
Operation code from which the recovery is being started.
Fault Code
Fault code from which the recovery is being started.
Recovery Type
The type of the recovery.
Flat Rate
Value of the amount if the recovery type is Flat Rate.
Start Date
Starting date of the part coverage.
End Date
Ending date of the part coverage.
Repeat the previous three steps for every part associated with the supplier warranty policy.
