Defining Properties for Workflow Process Steps
This task is a step in Defining a Workflow Process That Attaches an Activity Plan to an Opportunity.
In this topic you define properties for Workflow Process steps
To define properties for Workflow Process steps
  1. In the Process Designer, click the Add Activity Plan to Oppty step.
  2. In the Properties pane, define the business component and the operation using the values shown in the following table.
    Property
    Value
    Business Component
    Activity Plan
    Operation
    Insert
    If you configure an Insert operation on a business component, then you must supply a value for each business component fields that is required. To insert a new activity plan, you must provide the name of the template that Siebel CRM uses for the activity plan.
  3. In the Process Designer, select the Add Activity Plan to Oppty step and in the Multi Value Property Window (MVPW) pane, add a new input argument with the values shown in the following table..
    Field Name
    Type
    Value
    Template
    Literal
    A valid activity template name, such as Introductory Sales Call.
    For more information, see Arguments You Can Define for a Process Property.
  4. In the Process Designer, select the Display Activity Plan step and in the Properties pane, define the property shown in the following table.
    Property
    Value
    User Interact View
    Opportunity Activity Plan
  5. Click the connector that is located between the Display Activity Plan (user interact) step and the End step and in the Properties pane, define the properties shown in the following table.
    Property
    Value
    Event Object Type
    BusComp
    Event
    WriteRecordUpdated
    Event Object
    Activity Plan
    Type
    Condition
    The WriteRecordUpdated runtime event signals the end of the Display Activity Plan (user interact) step. Siebel CRM must wait for the user to make and save a change to the Activity Plan before it resumes the Workflow Process. WriteRecordUpdated signals this change.
