Guidelines for Configuring Backward Navigation
If you configure Siebel CRM to use backward navigation, then it is recommended that you adhere the following guidelines:
  • Make sure that any Workflow Process steps that Siebel CRM repeats as a result of using backward navigation do not result in Siebel CRM performing duplicative actions on data.
  • Note that backward navigation does not undo changes that the Workflow Process makes. It only modifies the current step counter to reference a previous step.
