Guidelines for Creating a Plan for the Test and Migration Strategy
If you create a plan for the test and migration strategy, then it is recommended that you adhere to the following guidelines:
Make sure your test environment and production environment contain identical software versions.
To make sure the test environment includes realistic data, you can use a partial or full copy of the production database.
