Output Argument Fields
The following table describes fields that you can define on an output argument for a business service step, sub process step, and Siebel operation step.
Field | Description |
Property Name |
(Required) Specifies the name of the process property that stores the results. If you click Property Name, then a drop-down list appears of process properties that are defined for the Workflow Process. For more information, see Passing a Process Property In and Out of a Workflow Process Step. |
Type |
(Required) Specifies the type or argument. You can choose one of the following values:
Value |
Specifies a string value. Use for Literal or Expression arguments. A string value can contain a maximum of 32,767 characters. |
Output Argument |
Specifies the name of the output argument. For business service steps only. For the Output Argument type of output argument. If you define an argument as a business service method argument, and if the Hidden field is set to FALSE, and if the type is Output or Input/Output, then the argument appears in this drop-down list. |
Subprocess Output |
Specifies the name of the output argument. For sub process steps only. For the Output Argument type of output argument. |
Business Component Name |
Specifies the name of the business component that the business object references. For the Business Component type of output argument. |
Business Component Field |
Specifies the name of a business component field. For the Business Component Field type of output argument. You cannot choose a field that references a multi-value group as the value for an input argument or an output argument. If you must use a field that references a multi-value group, then you must define a business component for the field, and then link it to the appropriate business object. For more information, see Configuring Siebel Business Applications. |
