Setting the Component Parameters Before Running Workflow Policies
When the changes for running the Workflow Policy are delivered to the Integration branch, set the WorkspaceBranchName to Integration Branch and run the following commands:
Component WfProcMgr
For example, set the component parameter WfProcMgr as follows:
Parameter WorkspaceBranchName="Name of the integration Branch"
Component GenTrig
For example, set the component parameter GenTrig as follows:
Start task for component GenTrig server <serverName> with exec=true privuserPass=DB Password privuser=DB Instance username=SADMIN password=<password>
Component WorkMon
For example, set the component parameter WorkMon as follows:
Start task for component WorkMon with SleepTime=10 GroupName=”Name of the Group Created” username=SADMIN password=<password> Pub Caret -1
