Using Parallel Processing in a Workflow Process
Siebel Workflow does not support parallel processing. Make sure you define decision conditions so that the Workflow Process can only proceed along one connector. If you do not do this, then Oracle cannot predict the runtime behavior of the Workflow Engine.
