Using Simple Comparison Operations
A simple comparison operation involves a comparison that Siebel CRM can express in a simple expression without using an iterative operation. The following table describes values for the following simple comparison operations: Between, Not Between, Greater Than, Less Than, Is Null, and Is Not Null.
Comparison Runtime Value That Results in a Successful Comparison Description
Between
Between two predefined literal values.
This comparison requires two values in the Values property. The Process Designer enforces this requirement.
Not Between
Not between two predefined literal values.
Greater Than
Greater than a predefined literal value.
Logically, only one value is required in the Values property.
Less Than
Less than a predefined literal value.
Is Null
Null or empty.
No value is required in the Values property.
Is Not Null
Not null or empty.
